General question
Old Jul 21, 2011 | 10:47 PM
mblausey89's Avatar
Smile General question
HI my name is Mike I have an 2004 honda accord lx and i need to replace a couple of things. Some of the things i need to fix but not sure if i should buy new or used.
The first thing that needs fixing is my front two headlights are foggy and i tried buffing them out. The previous owner scratched the hell out of them so i tried buffin them out but did not work. Should i look for used ones or buy new.
The second thing i need fixed is my hood has so rust damage and it needs to get replaced. Does anyone know were i could get a good one but not to expensive.
The third thing is i need two new bumpers i would perfer to get a new front bumper because it has some damage. I know all my back bumper needs is a new paint job but i am having trouble finding the paint color can you guys help.
Old Jul 21, 2011 | 11:03 PM
Peli's Avatar
The best thing to do for each of the things you've listed is to go to a local you pull it and see if you can find them. It would most likely be a lot cheaper than buying anything online. If you can't find the parts there try eBay.
What method did you use for cleaning your lights?
Old Jul 31, 2011 | 05:24 PM
Good suggestion for you to follow..
Good Luck
Old Jul 31, 2011 | 05:44 PM
You can check car-part.com for used parts near your zip code, or ebay.
Old Aug 1, 2011 | 10:14 AM
EXV6NIGHTHAWK's Avatar
It shouldn't be too hard to find a 7th gen Accord in a salvage yard. You could even switch from the 04 front bumper to the 06-7 style, if you wanted to. Advance auto, or other parts stores have the Dupli-color spray cans that you could use to repaint the rear bumper.
Old Aug 1, 2011 | 05:17 PM
kristech's Avatar
If that don't work if you just search around the many many sites for new headlights you can surely get one for a somewhat good deal.
However, I myself would also go to a salvage yard and look first cause it is way cheaper.
MARcelyCEL
May 11, 2010 06:52 AM
MOHORO25
Apr 1, 2009 07:00 PM
Shikaro
Oct 1, 2007 09:25 AM
91boz
Feb 6, 2007 12:52 AM
tibbo
Aug 31, 2006 01:59 AM
