getting ready for 5speed swap need help
Old Nov 19, 2012 | 06:12 PM
jroxz44's Avatar
Almost A Senior Member
Default getting ready for 5speed swap need help
Okay I have a 95 accord ex 2.2 vtec 153k with a decent amount of engine mods and I'm starting to notices the torque converter starting to slip alittle. And my buddy just wrecked the exact same car year, model everything except its a 5 speed. And he's gonna give me the tranny and motor before he junks it. And I need to know what kinda project I'm getting into doing a 5 speed swap and what all I need off his car before it goes to the crusher. I'm thinking with the engine mods its getting hard on the auto tranny. Or is there a aftermarket upgraded torque converter package that would be easier to do instead 5 speed. Any help is appriated I've never done one. I've replaces trannys just never a swap
Old Nov 19, 2012 | 07:00 PM
Search the forum for 5spd swap guide, there is a pretty good guide that lists every single part you will need. The only tricky part is the transmission mount on the body is different between the auto and manual cars so you have to cut and weld.
Old Nov 19, 2012 | 07:04 PM
Here is the list of parts:
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 Prelude)
3. 5 speed shifter assembly w/ shifter cables (90-97 Accord, 92-96 Prelude)
4. 5 speed drivers side axle (your year accord, but from 5-spd version)
5. 5 speed intermediate shaft (your year accord, but from 5-spd version)
6. 5 speed clutch pedal assembly (90-97 Accord, 92-96 Prelude)
7. 5 speed brake pedal arm (90-93 Accord, 94-97 Accord)
8. Clutch master cylinder w/ reservoir and lines (90-97 Accord 92-96 Prelude)
9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude)
10. Clutch dampener assembly (90-97 Accord 92-96 Prelude)
11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude)
12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude)
13. Slave cylinder (90-97 Accord 92-96 Prelude)
14. Clutch (90-02 Accord 92-01 Prelude)
15. Flywheel (90-02 Accord 92-01 Prelude)
16. 5 speed mount (Your year, 5-spd version) more info on this here: ***** Popular SWAPS/HYBRID thread index ***** - CB7Tuner Forums
17. 5 speed mount bracket (go to Honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00) (see notes)
18. MIG WELDER (see notes)
19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
20. Recommended: HELMS Service Manual (Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated)
Old Nov 19, 2012 | 08:29 PM
crispin's Avatar
I did this swap and did a write up of the process although the write up in the DYI section was much more detailed.
Have fun installing the new pedals, it was by far the most frustrating part of the swap.
PM me if you have any questions.
Also I recommend you buy the car from your friend for scrap value and take you time pulling all the parts you want then scrap the car yourself.
jroxz44's Avatar
Thanks. Lots of help. Hopefully everything goes good. We started pulling the tranny already. Seems fairly easy except for cutting and welding my own brackets which wont be too bad. Just time consuming. Thanks for the list. It will be a good winter project
Old Nov 19, 2012 | 08:31 PM
crispin's Avatar
What cutting and welding are you talking about????
Last edited by redbull-1; Nov 20, 2012 at 12:54 AM. Reason: Deleted unnecessary comment to OP.
Old Nov 19, 2012 | 08:33 PM
crispin's Avatar
Here is a pic of my 5 speed sitting where the auto used to be and not one thing was cut or welded.
Old Nov 19, 2012 | 08:35 PM
crispin's Avatar
I have done about 10,000 miles since the swap, not one issue.
Old Nov 20, 2012 | 10:49 AM
JC8643's Avatar
Crispin. Is that a new Output manifold? Or painted?
Old Nov 20, 2012 | 11:48 AM
crispin's Avatar
Are you talking about the exhaust manifold?
If so I just hit it with some high temp engine paint. It burns off pretty quick, I just wanted everything to look good after the swap.
Also you did not answer my question from before, what cutting and welding do you think you have to do?
