H.Accord-SE-06 (Rear wheen issue)
Old Nov 15, 2009 | 10:32 PM
backtothefuture
Unhappy H.Accord-SE-06 (Rear wheen issue)
Hi All, I'm new here. I took my Accord in today to a Honda dealer here in Canada (Erin Mills -Mississauga) as I've noticed a screeching noise while I reversing my car. I was told I needed to replace/do
Both rear pads + rotors = $ 594
Front Brake service = $68
ABS and brake flush =$ 149
Powersteering flush = $136
Air pollen filters = $115
Change both rear tires= $397
Alignment = $108
All of the above comes up to $ 1930 including taxes... I am really not sure if they are taking me for a ride.or does this sound reasonable and needs to be done..I 've got 90 kms on the odometer..well, in the meantime I got my oil and transmission fluid changed for $ 150...I understand its better to get it done at the dealer I am not sure if this dealer is pricing me right and if I need the above work-s done? PLEASE SUGGEST/HELP.
Old Nov 15, 2009 | 11:01 PM
That is way too expensive.
Find another shop and get another quote for the work. The work that needs to be done can be handled by any reputable shop. If you are nervous about aftermarket parts, see if you can buy the OEM parts for the shop to install.
Some of the stuff you can do on your own, like the pollen filters. They are very simple.
I don't know what the front brake service means.
Your owner's manual should have the intervals for the proper service intervals.
Old Nov 16, 2009 | 07:50 AM
finch13's Avatar
Wouldn't take it to the dealer for any of those services. A good shop will be able to do all that much cheaper.
I'd get new rear pads and rotors and the brake fluid flush. I'm guessing they're trying to charge more for the brake fluid flush by adding in the "front brake service".
The pollen filters can be changed yourself. Any chain tire shop can handle your tires just fine, most will even check your alignment for free. Make sure you see a printout of the specs before you agree to pay, so they won't sell you something you won't need.
Old Nov 16, 2009 | 08:51 AM
backtothefuture
Thank you guys, I thought as much, they were charging me more..I'll take it elsewhere and see...thanks alot.
Old Nov 17, 2009 | 07:00 AM
Some mechanics won't install pads if YOU buy them elsewhere. Or they won't warranty the work the same way. It's worth asking the question before you buy your own pads.
Old Nov 17, 2009 | 02:34 PM
backtothefuture
Thanks guys, I went to Canadian Tire and fortunately I ran into a nice tech and I told him about the quote and situation and he was nice enough not to cut corners but to give me a deep discount and fix everything listed above including 2 new rotors and pads for the front wheels...all came up to $1460 including taxes and a $20 coupon he gave me...
Reline disc brakes front - 89
Brake pad - 67
brake caliper slider guide front - 53
Brake rotor replacement front - two - 89
brake rotor - 2 - $114
reline disc brakes- read- $89
thermo quite - $57
brake rotor replacement two - rear - $ 89
brake rotor-2- $ 129
brake caliper slider guide - $ 53
rear surcharge - $ 53
new tire purchase install on -$39
Tires 2- 265
Replace air filter - $ 19
Power steering flush - $14.99
powersteering sealnt -$6.99
Bleed flush complete brake flush system - $ 89
their hourly rate is 99.99
total hours 6.51
Labour was $650 and parts total was $ 694
TOTAL INCL. TAXES I paid $1466....
I hope the above makes sense, well he used the 3 yrs warranty pads and 2yrs warrant rotors...
jza240sx
Apr 30, 2013 04:14 PM
azsmokey
Sep 13, 2012 02:22 AM
Cubeman
Jul 23, 2012 12:40 PM
Bobpt
Jul 21, 2012 09:55 AM
SC Tiger
Jul 11, 2011 09:15 PM
