Happy to be back, some issues when starting the car
Old Dec 25, 2016 | 02:54 PM
Rilex's Avatar
Default Happy to be back, some issues when starting the car
Good day to you all. My Honda car I left two months ago seems difficult on starting. I think is the security I installed is causing the problem. Because the security installation was done through the electrical system of the car and I think is beginning to fail. it was installed 4 years ago. the battery power is very good and also battery terminals. Any other suggestions from you guys. I will check the spark plugs tommorow and also I will remove the security I personally installed. Thanks
Old Dec 25, 2016 | 06:38 PM
More details. Is starter turning engine over but fails to start/run, or starter does not turn engine over.
Old Dec 25, 2016 | 11:26 PM
Rilex's Avatar
the starter does not turn the engine over but first let me remove the security and see what happens. thanks
Old Dec 26, 2016 | 09:14 AM
Wouldn't you test for voltage to the small wire on the solenoid first
It could be a bad starter?
Old Dec 27, 2016 | 12:44 AM
Rilex's Avatar
Good day to you all. TexasHonda you are right the problem is coming from the starter not the security. I was able to fix the starter. the car is starting smoothly now. I will also later raise up the discussion on whether to use single or double cell radiator. But presently the car came with single cell radiator. THANKS
Old Dec 27, 2016 | 03:42 AM
Rilex's Avatar
We are proposing adding a relay device to boost the starter when starting the vehicle. what do you people suggest. please reply soon. Thanks
Old Dec 27, 2016 | 05:29 AM
If it is like the 98 Accord's in North America, there is a starter relay in the drivers fuse box from the factory.
Old Dec 27, 2016 | 08:40 AM
The starter solenoid is a relay allowing low current ignition key feed signal to drive starter. See starter circuit diagram.
If starter is not engaging and blk/wht wire to starter has a 12V start signal from ignition switch, the solenoid has failed. Only fix is a new solenoid (not readily available) or new/rebuilt starter (usually available).
File Type: pdf
adanaccord
Nov 30, 2016 09:05 PM
jerbear812
Sep 27, 2011 06:12 PM
jdm_USO
Jun 18, 2011 11:34 PM
RhondaFondaHondas
May 11, 2006 12:14 PM
