Hard downshift from 3rd to 2nd
Old Oct 25, 2017 | 01:15 PM
Buddence's Avatar
Default Hard downshift from 3rd to 2nd
2001 Accord V6 automatic transmission, 160k miles. Fresh Transmission Fluid (drain and fill) less than 10k miles ago. Shifts perfectly except for downshift into 2nd. It’s not slipping, but rpm’s build and then 2nd engages with a slam rather than a smooth shift. All other up shifts and downshifts are fine. I’ve seen lots of issues with this particular transmission, however no one has described this particular issue. Can anyone steer me in the right direction?
Old Oct 25, 2017 | 01:51 PM
What fluid did you use? People have reported harsh shifting (in general) with non-Honda ATF.
Old Oct 25, 2017 | 02:15 PM
Buddence's Avatar
Purchased direct from Honda and done myself. Everywhere else in the shift pattern it’s great, just that one downshift.
Old Nov 25, 2017 | 05:08 PM
2000LX2.3's Avatar
Look at your shift solenoids; the screens could be clogged causing the hard shifts.
Old Mar 25, 2025 | 01:16 AM
Guamguy's Avatar
I have the same issues as well. I am trying to figure out what to replace or fix. It’s that one down shift. Have you got the problem fixed or know what it could be. Shifts well going all the gears but when in the neighborhood downshift to second is hard. Please let me know if you know what it was
JTyler2468
Oct 15, 2022 01:40 PM
freaknumber3
May 14, 2018 08:54 AM
camman
Sep 14, 2013 08:48 PM
Rotten kid
Apr 21, 2012 08:43 PM
strk500
Jul 7, 2010 01:01 PM
