HARD STARTING IN COLDER WEATHER
Old Dec 25, 2007 | 07:14 PM
collierville's Avatar
Default HARD STARTING IN COLDER WEATHER
93 4-DR EX A/T WITH 203K.
CAN YOU TELL ME IF THE MAIN RELAY WILL CAUSE A COLD STARTING PROBLEM.
WHEN THE CAR SITS FOR 10-12 HOURS AND THE OUTSIDE AIR IS ABOUT 30-40 DEGREES (STARTS IN WARM WEATHER NO PROBLEM). THE CAR WILL TURN OVER BUT IS HARD STARTING ( FUEL STARVED ?), LIKE THE MAIN RELAY SYMPTOMS. TRIED KNOWN GOOD BATTERY NO HELP. WHEN YOU TURN THE KEY TO ON, I HEAR THE FUEL PUMP AND THEN THE ENGINE LIGHT DOES GO OUT. ONCE YOU GET THE CAR RUNNING IT STARTS EVERY TIME. I AM ALSO WORKING A CRUISE CONTROL PROBLEM SO I HAVE THE CRUISE BOX OUT AT THIS TIME AND WILL PULL THE RELAY IN THE MORNING AND CHECK IT WITH 12V. IS THERE ANY OTHER TROUBLE SHOOTING I CAN DO. THX'S.
Old Dec 25, 2007 | 09:29 PM
Default RE: HARD STARTING IN COLDER WEATHER
My 90 Accord manual lists coolant temp sensor fault as most likely reason for hard starts in cold weather. Suggest checking coolant temp sensor against temp-resistance specs for your vehicle. CEL should show code 6 if sensor is shorted or open, however a working but inaccurate sensor might not set the CEL.
If the idle speed is low when you achieve cold start, the fast idle valve may not be opening to allow extra air for cold start. You can remove the fast idle valve cover and check for air flow when coolant temp is < 86F. If no flow under this temp, the fast idle valve will need to be replaced.
comuter
Sep 7, 2013 01:25 PM
Railey
Feb 18, 2011 02:42 AM
Accord_Ras
Apr 13, 2010 09:31 PM
petef23a
Dec 14, 2009 08:23 AM
LaurenK
Sep 29, 2009 07:56 PM
