harmonic/vibration problems
Old Feb 2, 2009 | 10:34 PM
petmos's Avatar
Default harmonic/vibration problems
Hi my 1998 2.4 auto vti accord is vibrating at about 60ks/35mph ijust had valve clearances checked/adjusted by honda dealer and no diffrence except abit more power. is the old girl letting me know she's getting loose in the crankshells, or has anyone an idea what?. thanks Pete
Old Feb 3, 2009 | 06:21 AM
Driving at a steady speed with the vibration, shift to lower gear but stay at the same road speed. Vibration stays the same?? If so, it'll be wheel balance. Or maybe a tire is beginning to go bad. Swap tires around to different corners to verify. It's not unusual for a wheel/tire to go out of balance over the life of the tire. Maybe a bent wheel from a pothole??
Old Feb 5, 2009 | 02:27 AM
petmos's Avatar
Default vibration probs
Thanks for that Jim. if anything changes e.g. going uphill or taking a bend, the shakes stop.I feel it's too fast to be a tire but they are due to be replaced soon so maybe that will solve the prob. Cheers Pete
Old Feb 5, 2009 | 07:24 AM
When you get new tires, have them look for bent wheels. Sometimes the balancing machine has safety shrouds around the spinning tire, so you don't see a bent wheel unless you make a point to look for it.
Chubbz
Jul 23, 2009 10:22 AM
StunkyElliott
Jun 18, 2009 10:02 AM
mrwigglezdj
Jul 28, 2008 03:55 PM
malachipeace
Mar 24, 2008 01:44 PM
gtrrambler
Aug 16, 2007 08:34 PM
