Has anyone ever seen this before!?? tierod sloppy on the threads
Old Dec 13, 2011 | 03:13 PM
fondahonda's Avatar
Default Has anyone ever seen this before!?? tierod sloppy on the threads
95 honda accord
first time jacking the car up i noticed the outer tie rod was very very sloppy where it screws onto the threads of the inner tie rod. (if there is an inner tie rod i havent checked yet) I unscrewed the outer tie rod which unscrewed right off with no tools. It was screwed on nearly all the way so that wasnt the problem. I was assuming the threads on the inner or outer were damaged but thats the thing they look just fine! I dunno if maybe the threads rusted down and used to be coarser? i checked the outer rod to the rod on the other side and it ppears to be the correct rod for the car and its stamped L and is on the L side. Maybe it goes to a different model? I must say i think this the first time ive seen this. It could have gotton someone killed...
Old Dec 13, 2011 | 03:40 PM
Check the new one real well for fit....was the "jam" nut there?
Old Dec 13, 2011 | 05:13 PM
fondahonda's Avatar
Default its not a new one, its the one that was on there
(outer tie rod) and it appears to be origional, The stop nut is on there and appears to be rusted in place pretty good, shoullda sprayed it with some blaster last night. In case ur wondering normally i dont work this slow but ive been taking care of a sick friend ( cat)
Old Dec 14, 2011 | 06:21 PM
We have to take care of friends
Check the other side, replace if needed, get the alignment checked after.
mtill58513
Apr 6, 2013 12:48 PM
Robert 1991
Mar 30, 2012 04:13 PM
bigstinker
Feb 27, 2010 02:16 AM
techstep
Oct 4, 2009 10:28 AM
pyrogeek
May 18, 2007 07:07 PM
