Having Electrical Issues with 2006 Accord V6 EXL
Old Feb 14, 2013 | 12:41 PM
Atl golfer's Avatar
Default Having Electrical Issues with 2006 Accord V6 EXL
During a simple drive my car will seem to conk out, but regain power instantly. However, the mileage for an oil change reminder will reset, the radio will need my access code to turn it on, etc.
I just checked the battery terminals and they seem mostly ok. It is a newer, dealer installed Honda battery, but looks like a small amt of corrosion is there. I took a hammer to it just now and knocked the terminals as to move them slightly and shake off any corrosion debris.
I should also add that I have 82k miles and have never had the timing service done. Could this be the issue?
Should this not take care of it, any other things I should try?
Thanks,
Atl
Old Feb 14, 2013 | 08:41 PM
Sounds like 2 possibilities.
1 Electrical connection for battery
Only because you mentioned the battery cables. Loosen the clamp, remove the negative cable then the positive cable. With the cables removed, follow the (+) cable and check that other end for being loose/dirty/corroded, and fix what you find. Same thing for negative cable. Clean & put the cables back on the battery. Don't use a hammer, because it can cause the battery to leak where the plastic is molded around the metal posts.
2 Ignition switch
Flaky ignition switches are not uncommon. If you can make it happen by wiggling the key, that clinches it. But if you can't make it happen by wiggling the key, that DOES NOT mean the switch is good.
The oil change reminder is the confusing part. Even disconnecting the battery should not reset the oil life calculation. I don't understand what can mess up the maintenance-minder.
Timing service?? Do you mean replacing the timing belt? That won't do it. If the belt breaks or skips time, it's NOT a momentary thing. It's bad damage and it doesn't snap back to being OK.
97HondaAccordMN
Jan 30, 2012 11:39 PM
brettboone1990
Sep 21, 2010 03:30 PM
986ci's
Apr 1, 2009 11:50 AM
jokster
Aug 11, 2008 06:24 PM
