06 Honda Accord - Any help?
I got an 06 Honda Accord that seems to be missing upon shifting. Its not really a hard shift, but more like its not getting enough fuel. If you start off from a complete stop at grandma speed (ha) giving it easy gas it seems to pull thru the shifts fine, but if you take off at normal speed it seems to miss really bad upon shifts..It may hold that miss for moment, or may just miss and switch on..I cant get it to get the codes until tomorrow, but thought someone might have a suggestion on what it could be.
Its been maintenanced well, and what not. I have a check engine light that looks like a transmission, and one that looks like a wrench..This isnt my car so I am unfamiliar with Honda icons..
If anyone can give any feedback/possibles here I would greatly appreciate it.
Thanks
Thanks
I would get the codes and description of the codes and post them here so the guys here can help, could be something minor like a pressure switch or an MLPS, or could be something on the engine side, but try driving it easy so the transmission won't get hurt too bad, i'd seen sometime people keep driving with a bad pressure switch for a long time, and when they coming to have the pressure switch replace the damaged was already done internally.
Code should be P2647. It's a circuit fault High Voltage. This would likely mean an open circuit. Bad wire, connector, or open solenoid coil.
Manual says to check oil level, reset ECU, and see if code immediately returns. If yes, then find the electrical fault.
Thank you all SO very much for your help..Right now I have changed the oil, and it seems to have helped...Its my best friends car but I think we are going to go try to trade it in tomorrow..Just seems it may be time..I do appreciate the help greatly.
junkmonkey99
12-19-2011 11:30 PM
ReDxAcCoRdx509
01-06-2011 04:51 PM
uthustler
12-16-2007 12:24 PM
