Having a spark plug problems on a 1991 accord
For some reason my spark plug wire keeps pop off the plug why the engine on
so i got new plugs it kept on
so i got new wires
and still it kept on
so got new value cover gasket/spark plug gaskets and still its keeps popping off
now this got me lost if someone can help i sure would
highly be thankful for the help
so i got new wires
There are two possibilities:
1) A plug is not sealing due to damaged cylinder head seal face. If this is happening on one cylinder, this would be my first choice. If one cylinder is having the problem, remove spark plug and look at seal face closely. You may need a borescope to get close enough w/o removing rocker arm assy to examine the seal face.
2) PCV system is blocked causing high crankcase pressure, or piston rings have heavy blowby (poor compression), again causing high crankcase pressure. Check PCV valve and hose for blockages. Replace as indicated. If engine is badly worn, you may be getting enough blowby under acceleration to elevate crankcase pressure which gets by spark plug tube seal to pop off the spark plug lead.
SeanAccord
May 18, 2010 08:24 PM
05HondaAccord
May 5, 2008 11:24 PM
busterdustercars
Apr 13, 2007 05:15 PM
