Head from F22B direct replacement for F22B2?
Old Feb 6, 2009 | 07:03 PM
john_g_46
Default Head from F22B direct replacement for F22B2?
I have a 94 accord. The head is destroyed...16 bent valves, broken cam and two dug out cam journals. Is the head from an F22B engine an exact replacement for the one on my F22B2 engine?
Old Feb 6, 2009 | 11:18 PM
F22B as in the DOHC JDM head? No you would need to do much more to put it on.
Old Feb 7, 2009 | 05:14 AM
john_g_46
No, the engine block is clearly stamped F22B2. It is a SOHC original head.
Old Feb 7, 2009 | 10:22 AM
So you want to replace a f22b2 head with an f22b2 head correct? If so, yes this will work.
Old Feb 7, 2009 | 06:13 PM
john_g_46
No, that is NOT correct. My question is, "Is the SOHC F22B an exact replacement for the SOHC F22B2?"
Old Feb 7, 2009 | 11:47 PM
I guess I am not familiar with a F22B motor that is SOHC.
Old Feb 9, 2009 | 02:55 PM
gdbog
I'm also interested in knowing the answer to this question. I think there is some misunderstanding. The existing engine is a stock F22B2. The head has been thrashed as described. Will a F22B head work on the stock F22B2 engine? there's a guy selling an F22B head and it LOOKS identical to the F22B2.
Many Thanks!!!
Old Feb 9, 2009 | 03:01 PM
finch13's Avatar
I would say no. The F22B was a DOHC head out of a Prelude. A B2 head shouldn't be hard to come by, I actually have one from my 95... I can sell it, but it's all taken apart. I could rebuild it for you....
toicy4ya
Aug 6, 2009 07:46 PM
Tom S. in Tn.
Feb 11, 2009 08:28 AM
falkore24
23
Dec 30, 2008 11:09 AM
dan_o_89_rs
Apr 28, 2008 07:47 PM
