Head gasket sealer
Old Oct 30, 2006 | 07:05 PM
corr04's Avatar
Default Head gasket sealer
Has anyone ever used Head Gakset sealer instead of replacing the gasket. i was just wondering if the stuff actually works/ and for how long? Just want my car to make it through the winter and don't feel like doing a head gasket or paying to have someone do it. Thanks
-Corr04
Old Oct 30, 2006 | 07:14 PM
deserthonda's Avatar
Default RE: Head gasket sealer
you mean for a blown head gasket ?,, sealer ?? mmmmmmmmm...
Old Oct 30, 2006 | 07:19 PM
sir_nasty's Avatar
all head gasket sealer I've used/seen is just a spray or glue etc to use in conjunction with a new gasket, if you're going to do it then put in a new gasket and don't risk warping your head
Old Oct 30, 2006 | 07:47 PM
corr04's Avatar
The stuff I got is called Head Gasket Repair from Bar's Leak. You're supposed to empty your coolant and dump it in there and run the eng. for awhile, it sets where there is a leak. I was hoping to get some feedback if the stuff actually works or not.
Old Oct 30, 2006 | 08:32 PM
sir_nasty's Avatar
I wouldn't use that.... it works occasionally but it can also block water passages, it's just like putting the radiator stop leak crap in, sure it will most likely find the hole but it doesn't know which hole it's finding.... that stuff can cause some issues, it usually works for a short time and is a NASTY little trick to cover up problems before selling a car (bad car lots use this crap a lot....) but I would NEVER use that stuff on any vehicle I intended to keep
Old Oct 31, 2006 | 12:04 AM
YeuEmMaiMai's Avatar
if you want the car to be reliable, you need to fix it right when it breaks down...that stuff will not work for long......
Old Oct 31, 2006 | 10:02 AM
MakoMan's Avatar
Yeah, I would really avoid anything like that, if it can plug up a blown head gasket, imagine what else it will plug up (radiator, water jackets etc.). But if you are dead set on using it, I suggest one called "Block Seal", I used it once years ago on an Olds Cutlass diesel and it sealed a cracked block for about a year until it just totally went out on me. That kind of stuff is really for last ditch efforts to keep something running, unless your car is a total piece of junk, don't use that stuff, just get the head gasket repaired.
JoeVR5
Jan 11, 2009 07:58 PM
Mott
Mar 24, 2008 03:55 PM
thunder_x
Jul 9, 2007 11:57 AM
Dshow
Apr 27, 2007 10:18 PM
dodins
Mar 18, 2007 08:10 PM
