Surging at low throttle/no load
Old Oct 31, 2006 | 01:53 PM
otherhonda
Default Surging at low throttle/no load
First issue to address with my '90 Accord...
Engine surges and stumbles slightly at low throttle loads and in lower gears. Check engine light comes on after starting and letting idle a couple minutes. Seems to smooth out and pull strong under heavy throttle and above 3000 rpm. Runs pretty rough at idle and shudders a bit when in drive.
Secondly...
Dash instrument lights are out completely and both indicators blink very dimly when either signal is activated.
Third...
I'm planning on getting a service manual asap. Any recommendations on preferred manuals? Is the CD/ROM version that you see commonly on Epay a good and comprehensive manual?
Old Oct 31, 2006 | 02:17 PM
MakoMan's Avatar
Default RE: Surging at low throttle/no load
You need to check the code to be sure, but the surging at low throttle is probably the TPS (throttle postition sensor).
Old Oct 31, 2006 | 03:05 PM
The BEST service manual is from www.helminc.com but it's a bit pricey. But worth it if you're gonna keep the car & work on it yourself.
Old Oct 31, 2006 | 03:42 PM
sir_nasty's Avatar
just download a free one
http://hondatech.info/downloads/Auto/Manuals/Accord/
bonafide
Jun 9, 2013 11:04 AM
Al_S
Jun 26, 2010 08:17 PM
Gary L
Sep 30, 2008 09:51 PM
480Ruger
Aug 21, 2008 06:04 AM
HondaAccordNewb
Oct 18, 2007 06:51 AM
