Headlight Adjustment
Old May 23, 2012 | 11:40 PM
94ex915's Avatar
Almost A Senior Member
Default Headlight Adjustment
For those of you that have adjusted the headlights on a 94-97 accord can you please tell me what tool you used. Im pretty sure I found where to adjust them (Gear looking thing in white casing) but it does not move at all. The horizontal adjustment I still cannot find. Right now here it what my headlights look like. And for those of you that notice the hood.... Please ignore the bird poop.... Birds went to town on it today..
Old May 24, 2012 | 01:01 AM
94ex915's Avatar
Anyone????
Old May 24, 2012 | 07:00 AM
I've had a 98 Accord, and other cars with those gear things for headlight adjustment. I've used a phillips screwdriver (try different sizes of screwdriver). The screwdriver acts like the pinion gear if you poke it into the proper position.
Old May 24, 2012 | 04:39 PM
94ex915's Avatar
Ya I tried with a philips and its a really long one. Cant fit the shorter ones down that far without them hitting something. Guessing I have to use a thicker philips.
Old May 24, 2012 | 09:53 PM
Dr. Drivability's Avatar
here's a diagram
Old May 24, 2012 | 10:31 PM
94ex915's Avatar
Originally Posted by Dr. Drivability
here's a diagram
Ya I think I found them just dont know what to use to adjust them.
Old May 24, 2012 | 11:09 PM
Turn the philips head screw with the properly sized screw driver. You may need to spray them with some WD-40 or PB Blaster.
Are you headlights securely bolted to the radiator support/bumper? If there is a lot of movement, this adjustment may not be noticeable.
Old May 24, 2012 | 11:21 PM
94ex915's Avatar
Ya they are securely bolted. I was adjusting a top screw on the left of the light and it looked like it was moving but I couldnt tell
kappakid
Jul 28, 2011 07:06 AM
GN517
Dec 9, 2009 05:36 PM
slow1500
Mar 18, 2009 07:47 PM
avulan
Dec 19, 2006 11:04 PM
Salamander1
Jun 28, 2006 03:21 PM
