headlight bulb replacement - can't turn bulb housing
Old Jan 18, 2007 | 01:47 PM
walker111's Avatar
Default RE: headlight bulb replacement - can't turn bulb housing
ORIGINAL: sir_nasty
try to rotate the bulb itself, I don't believe the outer black ring rotates
The bulb itself will NOT rotate, the black outer ring is what needs to rotate in order for the bulb to come out. Like I said before....either get someone with more "wrist strength" or move the battery to get more leverage.
Old Jan 18, 2007 | 01:54 PM
sir_nasty's Avatar
yes it will!! yes it will!! just kidding.... for some reason I thought that was the way mine were setup but I've been wrong on more than one occasion so it's all good *L*
Old Jan 18, 2007 | 02:32 PM
walker111's Avatar
ORIGINAL: sir_nasty
lol, thats the way the tail lights work
Old Jan 19, 2007 | 01:13 PM
sskkf
BLuEPiTBuLLz said:
it kinda broke them loose and i did the same thing putting them back on just in the other direction... its alot easier that way esp on the high beams where they are a lil hard to reach... and yes i had to take out my battery.
Since I am replacing my low beam bulb on the passenger side of my 95 accord, I actually have to remove the
air cleaner duct and air cleaner to have enough clearance to get more leverage on the outer ring. I really can't
get a flat screwdriver in there otherwise. I'm not sure I'm up to taking the air cleaner out, especially since the
screws are rusted and stuck on to the nuts and I probably need new nuts and bolts.
I may just bite the bullet and beg for mercy at my local RS Strauss Auto
K
Old Jan 19, 2007 | 01:54 PM
sir_nasty's Avatar
I'm not sure how it works on the accords but I know on my civic there were only a few bolts holding the aircleaner onto the body of the car, you can always remove those and bend/push the whole thing out of the way a little bit.... How long has it been since you've changed your air filter?
Old Jan 19, 2007 | 02:30 PM
walker111's Avatar
Remove the battery and turn the black ring..
<doesnt see how it can be this hard
Old Jan 19, 2007 | 02:54 PM
  #17
I had a similiar problem on my 95.
I sprayed small amount of WD-40 on the outside of the ring. I put a rag over the ring and turned. Once it realeased, it turned pretty easily. Just make sure to thoroughly wipe off all the WD-40, because it will drastically shorten the life of the new bulb if you get it on there and you'll be back to square 1.
Old Jan 19, 2007 | 04:21 PM
  #18
sskkf
Duh! Why didn't I think of that before?! (For some reason, I thought WD40 wouldn't work for plastic)
Thanks a lot, PAhonda! I finally replaced the bulb!!!!
I was careful with the bulb to make sure it didn't touch anything except the napkin with which i was holding it.
sir_nasty: um, i don't know when was the last time i changed the air cleaner. I am definitely going to
try replacing it soon. If you haven't guessed by now, I haven't really done much myself with my car.
I will try and keep up with this forum and learn a few things.
Thanks again to all who contributed.
K
Old Jan 19, 2007 | 04:23 PM
  #19
sir_nasty's Avatar
I just assumed that if the bolts etc were as bad as you were talking that it's been a while since it's been changed... Glad you got the bulbs changed at least!
eHonda
Feb 25, 2017 12:12 AM
grim_reaper
May 22, 2010 10:13 AM
rob3201
Jun 27, 2008 01:22 PM
tomatocity
Feb 18, 2008 12:07 PM
tomatocity
Jan 31, 2008 09:42 PM
