Headlight not bright any more
Hi, I noticed today that the headlights on my 2005 Accord LX are no longer bright and when driving on the dark road, I cannot see clearly and headlights are dimmer if looking at them, what is possible cause of this? I recently polish the headlight lenses and see big improvement on transparency and clearness on the lenses. Thx.
I've never heard of bulbs aging to a dimmer condition. If your battery voltage is low, the light brightness will be affected. However, you will have starting problems also.
If battery voltage is good, headlight bulbs are not terribly expensive, so perhaps replace one and see if it makes any difference.
May just be the bulbs. Honda had a service bulletin regarding certain bulbs:
Honda TSB 08-010
If the bulbs dim with the engine running, it may be due to the the Electronic Load Detector (ELD) having faulty solder joints. But, that doesn't sound like what you're describing.
http://www.skidmore.edu/~pdwyer/e/files/tsb/a05-034.pdf
Honda TSB 08-010
Honda TSB 08-010
Honda TSB 08-010
Smudgie
Sep 2, 2009 06:35 AM
