Headlight not bright any more
Old Dec 23, 2013 | 07:58 AM
wenmang's Avatar
Default Headlight not bright any more
Hi, I noticed today that the headlights on my 2005 Accord LX are no longer bright and when driving on the dark road, I cannot see clearly and headlights are dimmer if looking at them, what is possible cause of this? I recently polish the headlight lenses and see big improvement on transparency and clearness on the lenses. Thx.
Old Dec 23, 2013 | 01:37 PM
I've never heard of bulbs aging to a dimmer condition. If your battery voltage is low, the light brightness will be affected. However, you will have starting problems also.
If battery voltage is good, headlight bulbs are not terribly expensive, so perhaps replace one and see if it makes any difference.
Old Dec 24, 2013 | 05:28 PM
kris_loehr's Avatar
Do your headlights brighten with increase in RPM? If not check the amps your alternator is putting out and if that is good check for a bad ground.
Old Dec 24, 2013 | 06:12 PM
May just be the bulbs. Honda had a service bulletin regarding certain bulbs:
Honda TSB 08-010
If the bulbs dim with the engine running, it may be due to the the Electronic Load Detector (ELD) having faulty solder joints. But, that doesn't sound like what you're describing.
http://www.skidmore.edu/~pdwyer/e/files/tsb/a05-034.pdf
Old Dec 25, 2013 | 09:42 AM
wenmang's Avatar
Honda TSB 08-010
thanks redbull-1. I took out low beam bulbs and they match the potential faulty bulbs described in the bulletin and have them replaced with new Sylvania xtravision ones and will have them tested in next a couple of days. The second bulletin is also handy in case that the new ones not function as expected. High beam bulbs work fine on my car, only low beam ones have issue(oddly, I have not observed the issue before, only in recent 2 trips during the night, actually I have to turn on high beam on rural road on one of those trips otherwise, i can hardly see anything). Will report back the findings, thanks everybody for helping out.
Old Jan 1, 2014 | 10:28 AM
wenmang's Avatar
Default New headlights work now
After installing new headlights, headlight brightness returns to normal and I can see the road now. thx everybody for helping out.
Old Jan 1, 2014 | 11:16 AM
Glad it worked out and THANK YOU for coming back with the "end of the story". Too many times we never know how it worked out.
Codycancatch8
Jul 4, 2011 09:45 AM
dre707
May 18, 2010 05:52 PM
Smudgie
Sep 2, 2009 06:35 AM
guinnessmike
Jul 2, 2009 02:56 PM
accord5g
Aug 23, 2006 07:39 PM
