Headlights always on..
Old Oct 25, 2011 | 06:38 PM
samtycun's Avatar
Default Headlights always on..
Hi Guys
I need small help..I just got a 08 Accord LX-P and so far everything is great.
Just need small advice...on Headlights Auto On....
How to switch off that feature...as even on the sunny day...the headlights are on..which I feel is not correct..and also i have noticed several expensive cars..and I see them fine...
So need some advice here....appreciate any help..
Old Oct 25, 2011 | 06:47 PM
If you are referring the the daytime running lights (drl), they stay on until the headlights are on. The 8th gen Accords use the high beam bulbs at a lower power as the daytime running light. Once the low beam headlights come on, those go off.
Old Oct 25, 2011 | 06:52 PM
Here's a more technical explanation regarding the DRLs for the 8th gen Accords:
The North American Accords uses the halogen high beams on a low brightness setting for DRL.
The DRL system includes the driver’s multiplex integrated control unit (MICU), the passenger MICU, the left and right high beam headlights, and the DRL indicator. The DRL operates with the ignition switch ON (II), the headlights off (headlight switch OFF or in the parking position), and the parking brake released.
When the DRL are on, the MICU turns the high beam headlight control circuit on and off (duty cycle), which provides a reduced voltage (approximately 6-8 volts) to the high beam headlights (via the No. 1 and No. 28 fuses in the driver’s under-dash fuse/relay box and the No.1 fuse in the passenger’s under-dash ruse/relay box); the high beam headlights come on with reduced brightness.
Old Oct 25, 2011 | 07:07 PM
The Accord LX-P didn't have the auto on/off lighting feature like the EX-L and EX-L V6. So, you must be referring to the DRL, which is normal for it to be on in daytime or if the car's low beam headlights are off.
Attached Thumbnails Headlights always on..-auto-headlight-features.jpg   Headlights always on..-auto-lighting.jpg
Old Oct 25, 2011 | 08:05 PM
accordhybridowner's Avatar
My 2005 also has that light sensor under the windshield, but it has no daytime running light. I wonder what purpose that sensor serves.
Old Oct 25, 2011 | 08:44 PM
Your car is a 7th gen Accord, his is an 8th gen Accord; so, let's not start comparing apples to oranges and confuse the OP regarding his question.
The light sensor was for cars with the auto on/off lighting feature, not necessarily related to daytime running lights. If a car was not equipped with the auto on/off feature, there is just a plastic cover on top of the area where the light sensor would have been.
Old Oct 25, 2011 | 08:54 PM
As far as I know, none of the 2003-2005 models is equipped with DRL. Maybe the Canadian model does. So Honda put the sensor in the 05 model as a "plan ahead"? That's a bit of a tease... though it makes sense since they need to order the factory mold for the dashboard way ahead of the "7.5th" generation (06-07).
Old Oct 26, 2011 | 01:34 PM
samtycun's Avatar
Thanks everyone for your help and advise...and now it looks like...there is no solution to this...as to me it looks funny..that your lights are always on..even on a bright sunny day
Old Oct 26, 2011 | 07:23 PM
Tek310's Avatar
lift ur e-brake up one notch, they should go off. one notch will not engage the brakes
Old Oct 26, 2011 | 07:31 PM
The newer Hondas have far more electronics and sensors built in than previously. If the e-brake is one notch up and the car is driven, it starts beeping like crazy and a warning light will come on.
Stephanieajo
Mar 22, 2015 12:30 PM
Pilot Mobbin
Jan 30, 2013 07:18 AM
juanortanez031278
Feb 1, 2007 02:37 AM
1999Accord
Oct 18, 2006 08:18 PM
bougie_44
Jul 16, 2006 12:13 AM
