Heat Not working
Old Oct 16, 2007 | 09:11 AM
maro's Avatar
Default Heat Not working
Hi,
Well, my heat is not working. Vents are blowing, but no heat. I had heat last winter? Might I add, I suffered through the summer with no air. Though, the air has never worked in the year I've had this vehicle.
Any help for troubleshooting heater would be appreciated
thanks
Old Oct 16, 2007 | 09:20 AM
Default RE: Heat Not working
Start by checking the valve on the heater hose, near the firewall behind the thermostat housing. There should be a cable to work the valve's lever. Make sure it's hooked up & actually operates the valve when you turn the temperature control lever/dial.
Old Oct 16, 2007 | 09:28 AM
deserthonda's Avatar
Also pull the heater **** out , make sure that it is not broken ( cracked) .
Old Oct 16, 2007 | 09:31 AM
maro's Avatar
Will do! I'll check that out later
Wish I could say I missed you guys! We only get to "discuss" when the Honda is faulty.
Old Oct 23, 2007 | 04:53 PM
maro's Avatar
**** cracked. Where can I order a new one. Thanks for the help!
Old Oct 23, 2007 | 05:09 PM
The dealership has them for ~$6.
Old Oct 24, 2007 | 03:33 AM
2POINTautO's Avatar
If its the **** I think it is, ask for the updated part number, also Google for Grant Swaim, famous Honda guy, he sold these updated part numbers, if its the same **** I am thinking of.
skijour
Aug 15, 2012 08:31 PM
Cessna172
Nov 5, 2010 01:22 PM
Antarctica
Jan 31, 2009 03:25 AM
has1014
Dec 7, 2008 06:06 PM
vince_carnovale
Jul 18, 2008 07:38 PM
