heater
Old Nov 4, 2006 | 04:46 PM
2002haccord's Avatar
Default heater
Today was cold so i turned on my heater and it dont work unless the fan speed is all the way up to 4 if its not it dont work does any body know why?
Old Nov 4, 2006 | 05:22 PM
sir_nasty's Avatar
Default RE: heater
it might be the fan switch itself (the **** you turn) since 4 is typically the least commonly used setting it's the last one to go out, you'd have to pull it out to test it
Old Nov 4, 2006 | 05:43 PM
deserthonda's Avatar
Default RE: heater
most likely if fan does not work on 1-2-3 speeds you got a bad blower resistor
Old Nov 4, 2006 | 06:24 PM
Default RE: heater
how would i check the fan switch or if thats not it how do i check blower resistor
Old Nov 4, 2006 | 06:48 PM
sir_nasty's Avatar
Default RE: heater
if you look at the blower motor under the dash on the passenger side you'll see a few wires going to it, trace those wires back and they should go to a little box and that's the resistor... Hopefully that still works on the 02 models...
capww8
Jul 18, 2008 07:25 PM
soldierforchrist2
Dec 4, 2005 11:34 PM
millerlt4
Nov 6, 2005 10:44 AM
radmar1
Oct 25, 2005 10:02 PM
atreidies
May 2, 2005 02:38 PM
