HEATER HELP Please
Old Oct 27, 2005 | 01:49 PM
millerlt4
Default HEATER HELP Please
Ok I have a 1987 Accord LX with some heater issues.
the blower motor on the heater does not work unless you turn the key in the ignition switch all the way on and just about half way to the point on the ignition swithch were it will engage the starter. If you turn to far it will start the car. It blows hot and everything but only works if you turn the key in this fashion. Does the heater blower work off of the ignition switch?? Is switching the ignition switch a possilbe cure??
Is there anyway to hard wire a switch for heater operation??
Old Oct 27, 2005 | 11:02 PM
Evlampius's Avatar
Default RE: HEATER HELP Please
mmm very interesting - what about other stuff - lets say radio, Lights , rear defroster
does everything but the heater works normal?
i'm gonna make a research on that
Old Oct 31, 2005 | 04:05 PM
millerlt4
Yeah everything else works just fine! It is the weirdest thing. All accessories work, just not blower unless you turn that key over just prior to starter engage. Well the radio does not work come to think of it. Hmmm??
Winter is coming and I need a fix to keep the blower working. I wonder if a hard wired switch would work? Installed right to heater blower motor??
Old Nov 2, 2005 | 07:21 PM
899sei
Hi. I have an '89 Accord SE-i and am starting to have the same problem. Problem as follows:
Engine on: blower motor and radio have no power (sometimes they work)
Key on to position II: blower motor works no radio
Key on to position I: radio works normal
Engine back on: everything working ok.
Any idea's? Sounds like the electrical portion of the ignition? Weird thing is all other electronics work ok and the engine starts everytime too.
Old Nov 2, 2005 | 07:49 PM
RTexasF's Avatar
Super Member
I wonder if it could be the ignition switch?
Old Nov 6, 2005 | 10:44 AM
Evlampius's Avatar
If I were to guess i'd say Ignition Switch Electrical, but I really didnt want you to put in unneccesary part..
however - we just had similar problem on a BMW 528i which was fixed by ignition switch electrical so.
I'm 90% sure that it will fix the problem. The part should cost around $40-50 from a dealer. you could replace it yourself not really a big thingie. Requires some dexterity though.
timmy2dollar
May 29, 2013 06:07 PM
esan805
Mar 29, 2012 02:33 PM
art vandelay
Aug 2, 2010 09:29 AM
mamtsberg
Mar 17, 2010 09:15 PM
BIGWILBO
Apr 5, 2008 07:57 PM
