Heater blowing cool air on one side ?
Old Feb 16, 2010 | 09:19 AM
MSC71's Avatar
Default Heater blowing cool air on one side ?
2006 Accord v6:
Wife says the air coming out of the passenger side vents is not warm. Also said no air coming through the floor vents. Any ideas on what to check?
Old Feb 16, 2010 | 11:43 AM
Change the direction of the air (floor / dash / etc) to see if you can hear the motors running (pretty quiet) and moving the air-direction doors. Done any work in the dashboard where you might have inadvertently unplugged some wiring?
Old Feb 16, 2010 | 01:59 PM
MSC71's Avatar
thanks. no recent work in the dash. Are the doors just under the dash?
Old Feb 16, 2010 | 03:17 PM
#7 & 8 are the temperature motors for driver & passenger.
Old Feb 16, 2010 | 07:30 PM
96FiveSpeed's Avatar
Jim,Does that set up run off vacuum lines? I dont know how the car is built,but on other cars I have repaired,sometimes the problem was a busted or cracked vacuum line somewhere,preventing the doors from moving into the correct position.
Old Feb 17, 2010 | 10:38 AM
MSC71's Avatar
all the vents are working fine. The heat air did seem a little cool to me. I did notice the antifreeze was at the "min" mark. Could this cause the heater air not to be real warm??
Old Feb 17, 2010 | 11:05 AM
Those are electric motors. Older Accords probably used vacuum-motors, like most cars did back then. Don't know when they changed, but I had a 1998 & pretty sure it had electric motors.
Low anti-freeze can do it, but to be sure, check anti-freeze level in the actual radiator. There's a few reasons why the radiator can be low while the reservoir is full.
Old Feb 17, 2010 | 01:00 PM
MSC71's Avatar
I popped the cap to the radiator and it is to the top, but the reservoir is on "min" . I squeezed the upper radiator hose and it pushed some anitfreeze out of the radiator (cap off). Is that normal?
Old Feb 17, 2010 | 05:37 PM
Normal. You can add some to the reservoir knowing that the actual radiator is full.
If you squeeze the radiator hoses (cold engine & radiator cap closed), usually you can feel & hear whether there's any air in there. There should be no sloshing sounds.
After opening the radiator cap, usually takes 1 or 2 drives to work the little air bubbles out to the reservoir. If the radiator were low so you needed to add some, there's a bleeder valve at the thermostat where you can release trapped air. Hondas do not like any air in the cooling system.
EXV6NIGHTHAWK
Oct 9, 2010 10:35 PM
BHoward711
Apr 12, 2010 08:57 PM
jbraly
Sep 1, 2009 01:26 PM
skeenr
Jan 17, 2007 11:30 PM
soldierforchrist2
Dec 4, 2005 11:34 PM
