Hello ..new and need help
Old Jul 22, 2013 | 08:09 PM
justing920's Avatar
Default Hello ..new and need help
Have a 94 accord sedan ex nd its giving me problem when starting it wont turn over just sputters nd turns off replaced starter nd battery it will work after about 3-4 trys while steppin on the gas for it to start any suggestion to what the problem is. I dont know much about cars
Old Jul 23, 2013 | 12:08 AM
Lightbulb Hi , I'm moving this to correct thread :)
Welcome to the HAF..
Old Jul 23, 2013 | 05:57 PM
Terms can be confusing.
If you turn the key to start - does the starter spin the engine over but it won't "start and run" on its own?
Or, you turn the key to start and nothing happens - stater does not spin the motor?
We are willing to help, just need to understand the issue.
Also - does the CEL light come on when the car is running? And, are the tune up items (cap, rotor, plugs, check wires) up to date?
Old Jul 24, 2013 | 01:13 AM
justing920's Avatar
Yes the starter runs and spins but it wont start on its own i have to step on the gas while turning the key to get it to start nd. Im not sure bout that i dont know much about the maitnence schedule of the car just the oil changes
Nd etc.
Old Jul 24, 2013 | 01:14 AM
justing920's Avatar
Nd etc.
nd yes the cel is on came in when i changed the starter bout a yr ago think i need all of that tho spark plugs and all
Old Jul 24, 2013 | 11:14 AM
If you are unsure of the last tune up then I would plan on that - they wear out.
Get the code - at the top of this section there is a sticky - "Common DIY and Info Threads". In there you will see how to get the codes on you OBD-I car.
Once you have the code(s) let us know what it is.
Old Jul 28, 2013 | 06:07 PM
justing920's Avatar
Not to sound like a total moron but how do i get those obd1 codes will i have to get a diagnostics scan or whatever its. Called. ? Sorry on the late reply
Old Jul 30, 2013 | 11:12 AM
There is a service connetor under/behind the glove box....a blue two pin connector. Jump it with a piece of wire or paperclip and turn the key to on and start counting the flashes from the CEL - D4 - ABS.
Old Aug 2, 2013 | 06:01 PM
justing920's Avatar
I see a blue nd orange one so thats the blue one u were talking bout ? Nd its a 3 hole nd 2 hole when just to make sure thats the right connector just exactly how Do i jump it sorry im clueless when it comes to cars.
Old Aug 3, 2013 | 10:29 AM
Sorry but your post is a bit confusing.
For the connector there are several pic's floating around: 94 accord service connector - Google Search
tiehc
Jun 11, 2013 01:27 AM
dashindarlin
Jul 25, 2012 02:13 AM
Joecb7
Mar 20, 2011 09:14 PM
dhaa001
Mar 24, 2008 05:39 PM
ranger498
Feb 19, 2008 05:40 PM
