Help
Old May 11, 2021 | 01:27 PM
Pandahanda's Avatar
Default Help
I have a 2000 Honda Accord 2.3L 4c Manuel I just did a head gasket on and everything went 100% according to plan until I noticed a broken censor on the firewall side on the head under the intake manifold but I can’t find a diagram with it anywhere or figure out what it is please help so I can fix it
Old May 11, 2021 | 02:09 PM
The 2 sensors back there are the oil-pressure switch and the knock sensor. They're above the oil filter on the BLOCK, not the head. You said they were underneath the intake manifold, & the only thing I can think of on the HEAD would be the VTEC spool valve which is above the intake manifold.
#14 is the knock sensor & it has 2 wires.
#15 is the oil-pressure switch and it has 1 wire & a large rubber boot covering much of the sensor.
Old May 12, 2021 | 12:07 PM
Pandahanda's Avatar
Default Thank you
thanks after getting a better look it is on the block and I think it’s the knock sensor
Rubberman2003
Nov 28, 2009 11:59 PM
986ci's
Mar 29, 2009 02:14 AM
summerfish2001
Dec 4, 2008 02:25 PM
ximportxenx
Apr 1, 2008 01:44 PM
markjw
Jan 15, 2008 09:44 PM
