Help! Car won't start!
Old Jun 26, 2006 | 10:37 PM
motoprego
Default Help! Car won't start!
I have a 2000 Accord EX 4 cylinder sedan. It has ~56K miles. When I turn on the key, it just ticks. Starter motor does not turn over.
I checked the battery and it is fully charged. I checked the fuses and all of them are fine (not blown). The only things I noticed are the CD player/radio doesn't work (won't turn on) and the horn is weaker (does not sound normal). Checked all the wirings (that I can see) battery, groundings, etc and all seemed fine. Am I looking for a new starter motor? What can it be? Please help!!
Thanks in advance guys!
Old Jun 26, 2006 | 11:30 PM
mbo1985's Avatar
Default RE: Help! Car won't start!
I don't know, it sounds like your battery is weak. Did you test it for voltage? If it checks out at 12 volts I'm thinking it just doesn't have enough amps to get things moving. When your horn and CD player won't work, I don't think it's your starter.
Old Jun 27, 2006 | 12:15 AM
motoprego
Hey mbo1985, THANKS! for the quick reply. Really appreciated!
I called a buddy and he helped me look over the wirings and turns out the negative ground was loose. Tightened it up and the Accord is good to go again. I am happy again!
Cheers!
Old Jun 27, 2006 | 08:14 AM
mbo1985's Avatar
no problem! glad everything runs again!
olopez
Apr 1, 2010 07:18 AM
Hypnos08
Sep 9, 2008 11:19 AM
shawn till dawn
Jan 26, 2007 08:05 PM
Thisisnate
Aug 15, 2006 10:47 PM
