Help ! Crazy dip stick reading
Old May 31, 2020 | 06:48 PM
hmr's Avatar
hmr
Default Help ! Crazy dip stick reading
I own a 2000 Honda Accord EX sedan 4 cylinder with A/T. I carefully checked my engine oil dip stick today. Level was low below the lower mark. So, I thought that I could safely add a quart of Pennzoil 5W/30 conventional oil to bring it up. After letting the car set I checked the oil level. Now the dipstick reading is above the upper mark ! What happened and is it safe to drive the car with this apparent overfill ? Thanks.P.S. it looks like the new level is approximately 3/8 inch above upper mark.
Old May 31, 2020 | 08:34 PM
Seanjordan20's Avatar
Did you check it more than once the first time? I always check it 3 times to make sure
Old May 31, 2020 | 08:50 PM
What about the car being level?
A few mm above the top mark shouldn't matter much. How high is the level above the upper mark?
Old May 31, 2020 | 08:58 PM
hmr's Avatar
hmr
Approximately 3/8 inch above upper mark
Old May 31, 2020 | 09:17 PM
3/8 is too much. You're a quart over
Old Jun 1, 2020 | 01:17 PM
The Toecutter's Avatar
Probably more like a 1/2 or 1/3 quart over. He should have added a 1/2 quart then checked it, and added more if needed. At least that's how I do my wife's 2000 Accord LX with the 2.3L AT.
rockhoundrob
Feb 3, 2018 08:22 PM
hmr
Dec 25, 2013 02:32 PM
macmini05
Oct 20, 2011 01:33 AM
myfirstisanaccord
May 13, 2011 03:07 PM
joninja
Dec 1, 2007 12:13 PM
