help: Honda accord 97 transmission problems
Old Mar 3, 2010 | 09:49 PM
pakman420's Avatar
Default help: Honda accord 97 transmission problems
Hi, i have a 97 honda accord with only 69,000 miles. recently the transmission start to slip and shift hard. i got transmission conditioner and when i put it in it stopped the slipping and hard shifting until i woke up today and it was doing it again. what should i do???
Old Mar 3, 2010 | 11:34 PM
Is the D4 light flashing at all? If so, stop by an autozone and have them read the code(s). The connector is behind the ashtray. Post them on here. They will start with the letter P and have four numbers, i.e. P1234.
When was the transmission fluid changed last? Drain a bit of fluid out. Does the fluid look burnt or have any metal shavings in it?
Old Mar 4, 2010 | 12:17 AM
deserthonda's Avatar
like PA asked any codes ??? if none , you might want to have a shop chk the pressures ,,,,
Old Mar 4, 2010 | 09:08 AM
pakman420's Avatar
there was no light flashing and when i got it checked at autozone for codes, nothing came up. now the transmission fluid looks kinda bad. what should i do with that?
Old Mar 4, 2010 | 04:31 PM
I would change the fluid. Use the Honda ATF from the dealership. I put a link to a DIY writeup about changing the fluid. If you don't have a lift, drive the car around for 10-15 minutes to allow the fluid to mix, then drain and refill.
You also might want to clean out the solenoids.
https://www.hondaaccordforum.com/for...ad.php?t=30952
tacoguy3795
Nov 2, 2012 10:20 PM
Exigentik
Dec 14, 2011 02:18 PM
mamtsberg
Mar 17, 2010 09:15 PM
KimberlyC
Apr 16, 2006 11:51 AM
monroe
Oct 24, 2005 10:22 AM
