Help! I need answers!!
Old May 17, 2013 | 10:51 PM
CMR's Avatar
CMR
Default Help! I need answers!!
I have 94 Honda Accord LX coupe and today my windows would not roll up or down neither would any of my indicator lights come on, as well as the car wouldn't shift gears. It cranks up fine but doesn't shift gears. Has anyone ever had this issue or have an idea what it could be?
Old May 18, 2013 | 08:03 AM
Windows. Have you checked that interior lock switch is Off? Otherwise, check fuses in underhood fuse/relay box (fuses 15, 24, 25, 26, 28).
Shift Lock - First thing to check is whether your brake lights working? If brake lights are not coming on, the brake light switch may be stuck closed. Sometimes a good dose of WD40 will restore operation. Or, the rubber grommet which depresses the switch may have rotted and fallen out. Get a replacement plastic grommet from Honda.
david1212r
Aug 15, 2011 12:53 PM
DRREED
Jun 13, 2011 04:39 PM
runningback23
Nov 23, 2009 01:14 AM
liam71234
Oct 11, 2007 09:55 AM
phibbs87
Aug 18, 2007 11:17 PM
