Help with isolating suspension problem
Old Jun 25, 2014 | 12:18 AM
CD5.'s Avatar
Default Help with isolating suspension problem
I have the 96 V6 around 90k and driving on flat paved roads makes no noise at all rides smooth. Driving on dirt roads/paved roads when going over small dips or pulling in and out of parking lots, makes a squeaking noise and when going over larger dips sounds like metal hitting metal along with the squeaks. Also makes the same squeaking noise when steering left or right. Maybe ball joints is the metal sound? Shocks are newer and are in good shape so it cant be shocks. And as far as the squeaking is it the power steering? Help!!
Old Jun 25, 2014 | 07:38 AM
Try to simulate bumps by bouncing on car fender to initiate the squeaking. Likely need some help to cause bouncing while you inspect for source of squeaks. Feel upper/lower ball jts, tie rod BJ, tie rod for inner BJ, etc. You should be able to feel the vibration through fingers on steel parts.
Sometimes Anti-Sway bar guide bushings can cause squeaks. These are large rubber bushings that guide/support the AS bar at two points on suspension.
Old Jun 28, 2014 | 02:27 AM
CD5.'s Avatar
Ive noticed it only does the squeaking on the drivers side. Going to jack the car up tomorrow and check things out.
mamtsberg
Mar 17, 2010 09:15 PM
jojoliu861
Mar 26, 2008 08:49 AM
xpieceofcralpx
Dec 5, 2007 03:23 PM
Accordn2dis
Jul 22, 2006 07:37 PM
George Knighton
Jan 11, 2006 08:49 PM
