Help with lights
Old Dec 18, 2015 | 06:12 AM
Sclove's Avatar
Default Help with lights
I have a 1997 Honda Accord .the problem I m having is the front left signal in the front bumber don't work I have replace the bulb also replace the light socket still no signal light all fuses are good .what can it be please help
Old Dec 18, 2015 | 06:25 AM
This will require electrical fault tracing w/ a volt-ohm-meter or test light. Likely damaged wiring, corroded connector, or other fault.
First step is to check for 12v at the connector socket. It may be a bad socket.
If not trace wiring testing for voltage and ground.
csh217
Apr 30, 2013 09:03 PM
natthefisherman
Apr 12, 2010 11:20 PM
mamtsberg
Mar 17, 2010 09:15 PM
eccsc01
Feb 28, 2008 07:07 AM
marky4
Sep 5, 2006 03:21 AM
