Help Noise On New Accord
Old Nov 7, 2011 | 07:30 PM
zena_fan2000's Avatar
Unhappy Help Noise On New Accord
I recently purchased an Accord V6 Sedan. After a few weeks driving, I've noticed a strange sound that comes and goes. It's a very low droning noise which seems to happen between 35-40 mph. It goes away when you go above or below. I've noticed it when getting off of an exit and coasting at 35mph (no gas applied). What could it be? Any help would be great! Thanks.
Automatic Transmission
Old Nov 7, 2011 | 08:13 PM
Tire noise?
Wheel bearing?
Swap your tires around to see if the sound moves to a different corner.
Old Nov 8, 2011 | 12:36 AM
It does sound like tire noise..are your tires new with a lot of thread on them?
Old Nov 8, 2011 | 02:23 AM
lmrj0030's Avatar
more like a humming noise right? does the sound amplify when maintaining or increasing the speed a little and turning the steering wheel left/right?
If that is the case, it's a wheel bearing. make sure you change the right one and ASK YOUR MECHANIC what brand he uses. if you know your parts, suggest him to get a brand you like or they'll slap a generic that'll last you 20-30k before the sound comes back.
Old Nov 8, 2011 | 05:09 AM
Thanks for the replies. Yes, it sounds more like a humming sound; not metallic or grinding. The sound does not amplify with speed. In fact, it'll go away what's once I hit 40mph. It happens in range between 35 and 40. The car is brand new. The tires are brand new too. I would hate to think it's the bearings considering they should be new too. But, I guess I could have a bad one. Thanks again.
I haven't tried the left/right thing. Haven't found a safe stretch of road.
Old Nov 8, 2011 | 09:12 AM
k24acura's Avatar
The sound is when it is in 3 cyl mode. It goes away cause below 30mph all 6 cyl are on and above 45mph 4 cyl mode is used. Any acceleration and it fires on all 6. There is a bulletin on them so check with Honda.
Old Nov 8, 2011 | 11:07 AM
Thanks k24acura!
Is the noise normal? Or is something wrong with my Active Noise Cancellation?
Thanks.
Old Nov 9, 2011 | 08:58 AM
k24acura's Avatar
its normal. I thought mine was too.
Old Nov 9, 2011 | 09:30 AM
Thanks for all the replies. I'll just keep an eye out for any changes.
stockxplorer
Sep 25, 2022 04:15 PM
kikboxr1
May 17, 2010 09:56 PM
mamtsberg
Mar 17, 2010 09:15 PM
kingss
Mar 20, 2008 07:24 PM
atwood
May 1, 2006 08:59 PM
