Help please!!! 2006 Honda Accord
Old May 12, 2019 | 11:14 AM
shipo's Avatar
Originally Posted by Stanley Vanover
It does this when in park. When put in gear the wheels turn fine.
I'm not sure what that means; is the car up on stands or are you actually able to drive the car?
Old May 12, 2019 | 11:18 AM
Stanley Vanover's Avatar
I can let the car drive itsef when put in gear I have no throttle response when pushing pedal. It stays at a constant Rpm unless in parked can get it to go to 3000 RPM and the mph go up with the RPM when in park
Old May 12, 2019 | 12:38 PM
The Toecutter's Avatar
Still sounds like the axles aren't seated. If you have a rubber hammer, tap them in some more.
Old May 12, 2019 | 12:54 PM
shipo's Avatar
So you're saying you cannot take the car out on the roads and drive it. The issue is with your axles.
Old May 12, 2019 | 02:01 PM
I'm still confused...
So when the transmission is in PARK, you can rev the engine to 3000rpm? And when you do that the speedometer indicates something and the odometer also shows increasing miles?
Then when you put it in DRIVE, it will not rev the engine? The engine actually doesn't rev - as if the accelerator pedal isn't connected?
Old May 12, 2019 | 04:21 PM
shipo's Avatar
Agreed, we need a much more descriptive explanation as to what is going on. Long story short, the issue is probably the axles.
Milooo
Jan 26, 2023 06:09 PM
melissa111105
Mar 17, 2013 09:42 PM
jamola10
Jan 14, 2010 12:05 PM
