Sponsored by:
Sponsored by:
help with strange engine sound... 2001 lx
Old 04-27-2006, 09:10 AM
znayrbz
Default help with strange engine sound... 2001 lx
fixxd
Old 04-27-2006, 12:00 PM
deserthonda's Avatar
Default RE: help with strange engine sound... 2001 lx
when you say rotational,, do you mean engine rotation, car standind still and you can still hear the noise ?? OR moving rotation car has to be moving? what kind of noise is it ? rattling? whistling? humming ? scraping? whirling ?
when it comes to noises , it must be 1 of the hardest thing to help with , over the net, everyone interpetation of noises is different , but we will do the best we can to solve it..
if car has to be moving i would chk the brakes,
Old 04-27-2006, 07:14 PM
znayrbz
fixxd
Old 04-27-2006, 08:44 PM
sir_nasty's Avatar
It sounds to me like a belt... does the RPM's make any difference? Could it possibly be valve rattle and the wind noise drowns it out? Is it a constant noise at a low volume (prior to 20)?
When was the last time you changed your belts or timing belt?
Old 04-27-2006, 10:30 PM
SORRY but in this 1 i cannot give you the proper reply,, it could be so many things,, like nasty said could be belts, alt bearing, water pump beginning to wear, t-belt tensioner noisy, pcv valve hissing, .. to properly diagnose noises over the net is almost next to impossible ; i would have to be there to hear the noise first hand, to identify the source ..
you might have top do the eliminating process, get under the hood and try to pinpoint where noise is coming from,, remove the p/s belt and try it, if it goes away it is the belt or p/s pump.
, if still there, remove the alt belt and try it,, if noise goes away it is either, the belt, alternator, a/c compressor since alt belt also runs the a/c compressor,
you might want to take it to a shop and have them properly diagnose the noise, or you can wait till it might get louder so you can properly identify the source
Old 04-27-2006, 10:54 PM
Hi Nasty and Desert..
Good answers to his questions...did you guys remember to charge him the $83.00 per hour the garage charges???[sm=happy046.gif]
This id why we have such a good forum going here, good people helping good people...Thank You both for your answers...
Now (deserthonda) e-mail me and I'd like to ask you a few questions...okay!!!
WheelBrokerAng[sm=americanasmiley.gif]
Old 04-27-2006, 11:16 PM
znayrbz
fixxd
Old 04-28-2006, 12:17 PM
ORIGINAL: WheelBrokerAng
e-mail is on the way....
Old 04-28-2006, 04:58 PM
sir_nasty's Avatar
If you have never changed any of the belts on it do a quick inspection... Look for cracks in the belts/rubber on them, missing pieces etc. then feel along them and see if they feel hard/glazed over and/or rough if it matches any of that criteria I would change them regardless if that fixes the noise or not.... at least while you are changing them you can diagnose the noise more easily...
cat2115
04-26-2014 07:49 AM
briggsrepair
09-13-2013 10:17 AM
Dosobye
10-21-2011 10:34 PM
netb2b
05-06-2007 12:56 AM
Barmy
09-09-2005 02:20 PM
Quick Reply: help with strange engine sound... 2001 lx
