HID Light Help -_-"
Old Apr 24, 2009 | 10:09 PM
dragonle87's Avatar
Default HID Light Help -_-"
Hey I just bought a brand new black housing headlights from my friend & DDMTuning HIDs.
I installed them about a 1.5 month ago, & I recently noticed that the driver side is more brighter than the passenger side (slightly faded white/blue) So is this a bulb or ballast problem?
Any suggestions...
Thanks
Old Apr 26, 2009 | 03:13 PM
draser's Avatar
Can you swap bulbs?
Old Apr 26, 2009 | 05:18 PM
cjdm98's Avatar
I dont think its either. Your headlights may be aimed incorrectly. Causing the look of one being brighter than the other.
Park in front of a garage, or wall to see the alignment.
Old Apr 26, 2009 | 05:26 PM
finch13's Avatar
^ Word.
If they're aimed correctly, swap bulbs to the other side. If the bulb is dim on the other ballast, it's a bulb problem. If the bulb get brighter, and the other gets dim, it's a ballast problem.
Old Apr 27, 2009 | 09:43 PM
dragonle87's Avatar
I already did that...took me 30 minutes to aim it correctly. It's still a lil bit off
^ Word.
damn....its gonna be a b**** cuz the socket or the connector from the wire harness to the bulbs is very tight
I'm hoping it's the bulb cuz I screwed the ballast onto my bumper support (would DDMTuning still take it back?)
Old Apr 27, 2009 | 09:54 PM
botang47's Avatar
yeah if it really is a faulty ballast, their lifetime warranty should cover it
Old Apr 27, 2009 | 11:19 PM
dragonle87's Avatar
sigh...I'll be taking my front bumper off for the 5th time
Old Apr 27, 2009 | 11:21 PM
cjdm98's Avatar
Why should you have to take off your bumper for taking out ballast?
Old Apr 27, 2009 | 11:28 PM
dragonle87's Avatar
technically that's where i mounted....
the color is ok, its just the brightness
I try to look directly into my headlight reflector so I can take a look @ my bulbs & the passenger side is bright-white-yellow while on the driver side is white w/blue hue
however, standing in front of the vehicle with the HIDs turned on, the driver side is brighter than the passenger side (& yes my headlights are aligned)
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
hondaboostin
May 17, 2009 02:44 AM
