high miler
Old Aug 20, 2009 | 06:40 PM
rnurse's Avatar
Default high miler
I have a 99 accord with 195,000 miles. Not having any problems nor do i want any. What parts should i change out at this point? Wheel bearings, struts etc. Thanks
Old Aug 20, 2009 | 07:25 PM
Keep up on the scheduled maintenance, spark plugs, oil change, distributor cap, rotor, etc...
I would only replace parts that are worn out.
When was your timing belt last changed? Replace the belt when it is due.
Old Aug 21, 2009 | 06:38 AM
Yes, timing belt every 100k miles, so you're close to the 2nd time for that. Valve lash adjustment might be on a 100k mile schedule?
I used to have a 98 & the sparkplug interval was also quite long, maybe that's due.
For everything else, I would do a real good inspection. It's not possible to predict (based on miles) when you need brakes, clutch, & exhaust. When you rotate your tires, that's a perfect opportunity to take a real close look at the brakes along with all the rubber boots, like axle joints, ball joints, etc. Suspension bushings?
Old Aug 21, 2009 | 11:44 PM
deserthonda's Avatar
On top of all those suggestions ,replace the cabin filter as well as the air filter , tranny fluid , brake fluid every 30k, coolant every 30k,
PepeLePew
Jun 2, 2012 10:49 AM
MICHOASTYLE
Mar 15, 2012 06:16 PM
yamahabalu
Sep 28, 2009 02:11 AM
Landscape Architect
Apr 29, 2005 05:56 PM
Jan 12, 2005 02:46 AM
