HIgh Side A/C Line & Fitting
Old May 9, 2012 | 08:22 PM
pashwin's Avatar
Default HIgh Side A/C Line & Fitting
Hello,
I have a 2004 Honda Accord V6 Coupe with 78k miles. All of the sudden the A/C stopped blowing cold air. I took my car to a local mechanic for diagnosis.
The mechanic said the high side A/C line has a leak and has to be replaced and quoted $350 for replacing including parts.
Also the mechanic mentioned there is a power steering fluid leak and the hose has to be replaced. I was quoted $450 for this job. The mechanic showed me the hose under the hood which looked greasy.
I have no basic knowledge about car mechanics and I am not sure if I can trust the findings of the mechanic specially regarding the power steering hose replacement.
The only thing i have ever got done is replace oil/filter, brakes maintenance and brake fluid service. I have never replaced/flush the transmission fluid / induction service. The mechanic also recommended doing this.
I will really appreciate any inputs you guys can provide me.
Thanks,
Old May 9, 2012 | 08:29 PM
crispin's Avatar
Please do not make different threads about the same thing.
https://www.hondaaccordforum.com/for...fitting-47404/
Old May 10, 2012 | 05:41 PM
You can always take it to another place an see what they say.
The trans fluid should be changed (by the book) at 60K. I do not recomend a "flush" for a Honda, rather the simple drain and fill with Honda Trans Fluid.
I wouldn't worry with the other right now.
You are getting close to needing to change the timing belt - by the book, every 7 yrs or 100K miles.
Good luck
eduard
May 9, 2013 12:11 AM
phatboyslim2012
Aug 7, 2012 01:55 AM
PepeLePew
Jun 2, 2012 10:49 AM
pashwin
May 9, 2012 08:17 PM
suprarx7nut
Jun 21, 2007 12:03 AM
