Highway driving
Old Feb 10, 2005 | 11:00 PM
tai63
Default Highway driving
I have a 03 Accord coupe with the factory Bridgestone EL-41's. At highway speeds, it drifts in either direction. On windy days, it is extremely hard to control. I keep it aligned and have had it rotated and balanced several times. Is this a engineering flaw or is there a tire or suspension problem? Your help is appreciated.
Old Feb 11, 2005 | 03:06 AM
Default RE: Highway driving
Hello Tai63
Welcome to the forums..
There may be uneven tire wear problem, so check your tires..
Also you may have a lack of lubrication at the ball-joints and at the tie-rod ends..make sure your mechanic is lubeing them when he's doing your car.
You could also have a sagging or a broken spring or strut under there, check that out.
Worn strut plates and also check for a loose stablizer bar...that could also be the culprit.
Hope this helps you out...Again Welcome to the forum..
WheelBrokerAng[sm=icon_blah.gif]
Old Sep 1, 2005 | 09:31 PM
tai63
Hello WheelbrokerAng
I have new tires and the problem remains. The suspension has been checked out and no problems have been found and I thought that all components were lubricated for life. Are the spring and strut potential issues one that require a more intrusive search other than a visial inspection? I am beginning to suspect that this is a charcteristic of this model and there is nothing that will change it. Let me know what you think.
Old Sep 6, 2005 | 11:44 PM
RTexasF's Avatar
Super Member
What tire pressures are you running? It's possible that you got a bum set of tires or allignment. The allignment machine is only as good as its operator.
Old Oct 3, 2005 | 07:59 AM
tai63
The tire pressure is 32psi all around. I just replaced them with Bridgestone LS-V's and although better, the problem is still there. Also, I have had alignments performed at several different shops so I am not sure that the alignment is an issue.
tokarev
Jan 9, 2012 06:19 PM
darkgreen18290
Sep 13, 2011 05:12 AM
stonesfan
Jul 28, 2011 09:32 PM
charliemcfarley
Mar 24, 2009 10:20 AM
terrypdoherty
May 7, 2006 11:21 PM
