Hissing Noise From Air Vents
Old Dec 7, 2006 | 11:56 AM
spliffy
Default Hissing Noise From Air Vents
Hi,
I have a 2001 Accord Coupe 2L / 4 cylinder.
My problem is this...when I have the a/c on, i am getting a slight hissing sound coming through the air vents, as soon as the a/c cuts in.
Also, when I switch the engine off, the hissing sound comes on again, for about 10 seconds. It sounds a little bit like a boiling kettle.
I've also notice that when the a/c or climate control is on, the RPM fluctuates between 800 and 1500 ( I think, as the a/c cuts in and out).
I was wondering if it needs re-charging.
Any advice would be appreciated !
Old Dec 9, 2006 | 10:20 AM
spliffy
Default RE: Hissing Noise From Air Vents
Surely I am not the only one to suffer this problem !
Old Dec 9, 2006 | 04:18 PM
deserthonda's Avatar
i ave seen a few times where you have to evac and recharge the a/c system...........also make sure that the vents are fully open ,, if they are slightly open ( almost closed ) the air flow will make a hissing noise
Old Dec 9, 2006 | 06:03 PM
spliffy
Thankyou for the reply, but it's not due to blockage of the vents, since it continues after you've parked and sounds like a boiling kettle.
Maybe a re-charge is the answer.
Old May 5, 2007 | 10:22 PM
spliffy
To answer my own question, A recharge didfix the problem.
Seems it was totally empty.
ICAN'T BELIEVEany of you guysdidn't knowthe answer to my problem.
Old May 6, 2007 | 01:44 AM
You failed to mention the system was not cooling. If it was cooling it was not totally empty. If no leak was repaired, you will soon have the same problem again.
Old May 6, 2007 | 03:54 AM
00AccordLX5spd's Avatar
Registered User
I second TexasHonda above.
It's kind of hard to know the answer to your problem when the description is incomplete.
Old May 6, 2007 | 04:25 PM
ckebottle's Avatar
ORIGINAL: deserthonda
Wow. Desert said right there to recharge the system. So what the heck are u talking about nobody knew the answer?
Bryan Norgard
Aug 3, 2012 08:42 PM
92Wahoo
May 18, 2009 07:35 PM
00AccordLX5spd
Feb 17, 2008 03:14 PM
xlibe
Dec 28, 2007 03:25 AM
philzy87
Jul 9, 2007 07:06 PM
