honda accord 1987
Old Jul 2, 2006 | 12:22 AM
strbo32098
Default honda accord 1987
Ok i have an 87 accord and my car is idling at 2500rpm when its on park. I usually this happens when my car is cold and just needs to be warmed up. Usually when i rev the engine a couple of times the rpm will drop to normal. Now it just stays at 2500rpm. When i throw it into drive of course thers a big clunk and the car will drive 40 mph without me step on the gas at all. Im thinking its the carbeurator, being stuck open or something. What do you guys think?
Old Jul 5, 2006 | 04:45 AM
strbo32098
Default RE: honda accord 1987
Ok i took off my carbuerator and cleaned it up with wd-40 and put everything back. The car seems to be idling at around 700-800 rpm which is normal for my car. The problem now is that the would just die after 1min of driving it. Then i try to start it again, it starts up and just dies after 2 seconds of running. I wait until the car cools down and i can start it again and drive it for about 1min and it would die out again. anybody know a solution to my problem?
Old Jul 6, 2006 | 04:07 PM
hondaeng
What kind of routine maintenance have you done? Air filter, pcv valve, egr valve, fuel filter,,,,,,,,,,?
Old Jul 7, 2006 | 11:33 AM
89HondaLegend's Avatar
I have the same problem with my '88 Accord. The car will run at about 2500 RPM and occassionally run at normal RPM's.
Replace your PCV valve and see if that helps. I still need help on figurning out what is causing this intermittent high idle on my car. Is there a Fast Idle valve or something ? Need some help guys.
Old Jul 8, 2006 | 11:52 AM
BUMP...
Old Jul 2, 2017 | 07:18 PM
swiftymorgan's Avatar
Default Carburetor Icing
I had the same problem with my 87 LX, turned out to be carburetor icing caused by a defective divert baffle on the horn of air cleaner. I fixed it with bailing wire so carb heat is always on in cold weather.
I know this is an old thread but maybe this might help someone.
jdmcginnis
23
Jul 25, 2013 08:54 PM
45below
Sep 16, 2010 03:26 PM
Honda Enthusiast
Aug 8, 2010 09:43 PM
mainman1963
Nov 22, 2009 11:55 PM
87hatchback
Aug 17, 2007 08:17 PM
