Honda Accord 1998 LX 4cyl starting problem
Old Jan 26, 2011 | 08:21 AM
superdappa's Avatar
Thanks Jim, i will check the cylinder and see if it is bad also i will buy some NGK plugs in the future as well. thats what the honda had in it before i changed them.
Old Jan 26, 2011 | 08:40 AM
Remove plastic shrouds around steering column.
Key cylinder is top-right in this picture. The electrical part is attached to the other end, its #14 in the picture.
Old Jan 26, 2011 | 06:42 PM
I recently removed a set of Bosch platinum tip plugs from Acura 03 MDX due to multiple misfires. These plugs have the tip submerged below flush on the insulator. This allows for easy fouling.
I replaced w/ Autolite platinum coated plug. I've had good results on several cars w/ these and they are quite inexpensive. They have a conventional tip arrangement w/ a spot of platinum layer on tip and ground side (DPP).
Tmangino7
Apr 11, 2013 05:18 PM
evansd12006
Oct 9, 2011 09:12 PM
techjohnny
Mar 30, 2011 09:17 AM
techjohnny
Mar 14, 2011 06:25 PM
djstylze
Jul 9, 2010 01:17 AM
