honda accord 2.2 97 engine vibrate...need help!!
Old Dec 12, 2007 | 12:42 AM
kaweonly
Default honda accord 2.2 97 engine vibrate...need help!!
i'm just new with honda car. I just have bought a honda accord 2.2 (a) 1997 last month.
My car vibrates when in idle mode. is that because of engine mounting or something else?
Can anyone here help me? I'm try to use engine oil Mobil 1 5W-50 for my car. is that best or worst to my car engine? plss.. i need help.
Old Dec 12, 2007 | 09:25 AM
YeuEmMaiMai's Avatar
Default RE: honda accord 2.2 97 engine vibrate...need help!!
check to see if it is misfiring
check your rear engine mount and make sure it is working properly
Old Dec 12, 2007 | 10:51 AM
nafango2's Avatar
5W-50???
im guessing that was a typo... but you should use either 5W30 or 5W20.
mobil 1 is a good oil, as far as oils go.
As far as synthetic oils go (the best in most areas) some of the best are royal purple, amsoil, and Valvoline SynPower.
Old Dec 12, 2007 | 11:51 AM
deserthonda's Avatar
like it was mentioned, You need to verify if it is an engine miss or bad mounts. And also use 5w-20 or 5w-30 oil..
Pull plug wire one at a time and see if the idle speed drops or stays the same.. if idle speed drops that cylinder is firing.. if idle speed stays the same that cylinder is not firing ( engine miss)
Old Dec 12, 2007 | 06:50 PM
HondatechAV6's Avatar
yeah, check motor mounts.
is the idle speed steady?
possibly balance shaft alignment wrong?
Lovemy97HondaAccord
Mar 5, 2014 06:04 PM
Solja36
Dec 19, 2012 01:07 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
Brendo613
Feb 23, 2006 07:26 PM
