Honda Accord 2000 AC Groud Wire
Old Feb 5, 2010 | 03:40 PM
npverma's Avatar
Smile Honda Accord 2000 AC Groud Wire
Last year there was no air comming out of my AC vent and I took it to the autoshop and they mentioned it a Ground Wire problem which they told was loose. Now again the same problem and I want to find out the Ground Wire under my hood so that I can tighten it, if it's loose. Does some one know the location of the Ground wire.
Old Feb 5, 2010 | 03:51 PM
It will be on the a/c compressor. It should be the only wire that is bolted to the housing.
Look at compressors on E bay for your car and you will see what I mean. I would unbolt that ground, clean up the contact with some sandpaper, then tighten it back down.
Old Feb 9, 2010 | 04:43 PM
npverma's Avatar
Thanks , I was able to locate it with your help, but somehow it automatically started working so no repair required.
dizzy5506
Feb 13, 2023 05:47 AM
fjpthree
Apr 4, 2013 10:28 PM
understand1
Nov 10, 2012 11:06 AM
humblehyper
Nov 19, 2008 12:26 AM
HONDA90
Oct 1, 2007 10:54 AM
