Honda Accord 2000, tachometer and speedometer stuck below resting peg
Old Nov 1, 2010 | 02:26 PM
hondan00b's Avatar
Exclamation Honda Accord 2000, tachometer and speedometer stuck below resting peg
not sure what happened, we had some battery issues, and recently replaced our battery, after figuring out the radio code,
i noticed that the tachometer and speedometer are now below the resting peg, seems like they went all the way around.
All other meters are working, but the tachometer and speedometer seem to work, they just cant get past the bottom resting peg. Both the tachometer and speedometer move from straight down, almost 6 o'clock position to the 0 speed position under the peg when i turn the key, but they stay there until i turn the car off.
Anyone know of a fix?
Old Nov 1, 2010 | 08:23 PM
You may have to remove the cluster, take it apart, then lift the needles over the peg? Be careful not to break/damage the needles.
Old Nov 1, 2010 | 09:18 PM
hondan00b's Avatar
after searching the forum and searching google, i discovered that if i clean the corrosion and unplug the battery and replug it in, it corrected itself. done 8) easy fix
Old Nov 2, 2010 | 06:55 AM
Interesting...
We'll have to remember that for the newer (ECU-driven) clusters.
jreniak
Oct 28, 2014 08:21 AM
erader00
Aug 19, 2012 08:51 AM
Spinninwrenches
Aug 9, 2012 09:28 PM
boerckk
Sep 21, 2010 07:03 PM
lordsusanoo
Aug 20, 2010 09:54 AM
