HONDA ACCORD 2003 transmission problem
Old Mar 15, 2015 | 07:57 PM
Munkhuu Saikh's Avatar
Default HONDA ACCORD 2003 transmission problem
I have 2003 honda accord V6 coupe automatic. I was driving and turned and pressed on the accelerator little harder than normal. Then boom, i heard something go pop. Then i couldnt accelerate anymore, i had to roll it onto side of the road. I put it in park, then i heard some grinding noise, quickly turned it off. Turned it on, put it drive, no luck, not moving, the speedometer moved, but car didn't move. Turned it off in drive then shifted into park. But now the car doesn't start, it makes some twitching noise, but doesn't turn on. I turned the key to ON, but the light shows green light next to Drive and park at the same time. The gear might be stuck in drive, and i can't put it back to park. Even i put the shifter to Park, but i think it's still stuck in drive. So can someone help me what the problem is and why my car stopped starting? Do i need to replace the transmission? I looked up some stuff on the internet, and apparently the transmission in honda accord 2003 is notoriously bad, and i didn't know. Help me what to do? Thank you.Should i replace, or look for a new car?(i just replaced brakes and oil, new tires )
twofactor23
Aug 26, 2012 04:53 PM
trouble
Aug 21, 2012 07:46 PM
Metallica2010
Dec 28, 2010 03:10 AM
Sheryl S
Sep 10, 2009 09:59 AM
hondaR
Sep 22, 2007 11:34 PM
