2003 Honda Accord LX 4-cycl Transmission Fluid Change
Old Sep 9, 2009 | 08:41 PM
Sheryl S's Avatar
Default 2003 Honda Accord LX 4-cycl Transmission Fluid Change
Hello,
I have a 2003 Honda Accord LX 4-cycl. auto transmission, 4-door with 36600 miles. I purchased used and I'm not 100% sure if the transmission has ever been serviced.
I just want to make sure I have all my bases covered.
First, remove the transmission dip stick?
Next, remove the transmission drain plug and drain the fluid?
Then, replace the plug with a new (crush gasket)?
Last, put 3 quarts of transmission fluid back in?
I hope this is how it's done.
I do have a couple of questions.
Is the trans. plug gasket the same as the oil drain gasket?
Must I use a torque wrench when replacing the trans. plug?
If so, does anyone know how much torque to set the wrench with?
Thanks,
Sheryl
Old Sep 10, 2009 | 08:21 AM
Firstly, automatic & manual trannys are very different. And Honda 4-cyl and V-6 trannys are different, so there's 4 completely different trannys here.
You said you have a 4-cyl engine. Since you mention the tranny dip-stick, I guess you have an automatic tranny? Yes, you have the right procedure for an automatic.
Beginning in 2003+ auto trannys (for the 4-cyl engine), the drain plug is located near the front-center of the engine (on the very bottom of course). The plug faces towards the right-side of the car, it doesn't face down. The plug has a square hole in it, for you to use a 3/8" socket-wrench handle without a socket.
The total amount of fluid is something like 7 quarts, but only about 3 quarts will drain out. Catch some as it's draining - if it's dirty, I suggest changing it 3 or 4 times; drive around a bit in-between to mix up the fluid. Also, if it's dirty, in the future change it more often so it doesn't GET so dirty next time.
The drain plug has a magnet. It's sorta normal to have some sludge sticking to it, so wipe that off with a rag. There should NOT be any big chunks; that would be a bad thing.
I think the tranny drain plug and the engine drain plug aren't the same size, so it's a different-size crush-washer.
I normally snug it up, without a torque wrench. The shop manual DOES list a torque (maybe I'll remember to look it up).
Fill with about 3 quarts of Honda ATF. Make sure you check the oil-level on the dipstick, because it may drain more or less depending on how level the car sits. Don't just close the hood after adding 3 quarts.
Old Sep 10, 2009 | 09:24 AM
Sheryl S's Avatar
Hello JimBlake,
Thanks so much for your help.
Yes, sorry that I did not mention the trans. is an automatic.
You mention if the trans fluid is dirty to repeat 3 or 4 times.
So I may possibly need 9-12 quarts of Honda ATF and 3-4 crush washers?
And, you mention if it's dirty to change it more often in the future. Approx. 20k miles?
I just want to be sure I'm understanding what your saying.
Thanks again for all your help,
Sheryl
Old Sep 10, 2009 | 09:59 AM
ONLY if drains out dirty. Then re-use the crush washer until the FINAL fill-up. Actually, I re-use the crush washers several times anyway. But those washers don't cost much anyway.
Yes, possibly need 9-12 quarts. But PROBABLY not. Most likely one drain/fill is all that's needed. Then judge future intervals based on how clean it looks. 36k miles is probably sooner than the owner's manual calls for anyway.
62maxx
Oct 18, 2015 08:20 AM
Scottermac
Apr 10, 2015 07:12 PM
koolguy123
Jun 2, 2014 09:25 AM
RoKnAzn
Jun 16, 2006 01:37 PM
dave118811
Mar 26, 2006 11:09 PM
