2K Accord LX 4 cycl overheating
Old Apr 9, 2015 | 06:10 PM
Scottermac's Avatar
Default 2K Accord LX 4 cycl overheating
My 2000 Accord LX 4 cycl is over heating. Temp gauge is hitting the redline. the radiator fans don't appear to be coming on when the engine comes up to temperature. Fuses are good, and both fans will run when the AC is on. I did just change out a heater hose. Where should I look next for a possible fix? Your help would be greatly appreciated.
Scott in Savannah
Old Apr 9, 2015 | 10:32 PM
Did the overheating happen before or after replacing the heater hose?
Did you purge air from the radiator after replacing the heater hose? See this video:
Old Apr 10, 2015 | 03:09 AM
Scottermac's Avatar
Thanks for the video link. I'll try that tonight. To answer your question, yes it started running hot before I changed the hose. The hose was leaking.
Old Apr 10, 2015 | 07:56 AM
Turtlehead's Avatar
With the car off and a funnel attached to the radiator open the 12mm head bleeder bolt located on the back of the intake on the passengers side. Allow it to drain and bubble until fluid comes out smooth and free of bubbles. If air surges out when you crack it then there is a good chance that is the problem.
Old Apr 10, 2015 | 07:12 PM
Scottermac's Avatar
Adding coolant and bleeding the system took care of it. Everything appears to running fine. Thanks for everyones help. Off to the next project.
koolguy123
Jun 2, 2014 09:25 AM
Sheryl S
Sep 10, 2009 09:59 AM
RoKnAzn
Jun 16, 2006 01:37 PM
dave118811
Mar 26, 2006 11:09 PM
erikhaha
Nov 20, 2005 02:48 AM
