Honda Accord 2005 unlock receiver not working
Old Jan 15, 2019 | 04:33 PM
Atish Singh's Avatar
Default Honda Accord 2005 unlock receiver not working
I have honda accord 2005 and the unlock receiver module is not working. I have replaced the remote fob battery and sometimes it works when i unlock from remote very close to the drivers door. Anyone has a fix to this issue. Thanks.
Old Jan 15, 2019 | 04:44 PM
Seanjordan20's Avatar
Have you tried your other key? If not try it to make sure it is that key. If the other key is doing the same thing then replace the master window switch and reprogram the fobs to the car. You can find the instructions on YouTube.
If it is indeed the key then the part you need to replace is 72147-SDA-A11.
Usually if you have to be close to the car to unlock it with the fob it's the battery. What battery are you using (is it a good battery)
Old Jan 15, 2019 | 11:13 PM
I have changed to battery and both fob key is not able to unlock.
snowshovel
May 22, 2014 12:56 PM
Hondafan454
May 19, 2012 08:50 AM
WhiskeySlick
Aug 9, 2011 01:12 PM
GimmeAdecentIPodUI
Jun 29, 2011 12:11 AM
01AccordCoupe
Dec 11, 2007 10:32 AM
