Honda Accord 2006 break jam
Old Oct 14, 2012 | 02:36 PM
Sm1976's Avatar
Default Honda Accord 2006 break jam
Hi,
I am owner of 2006 Honda Accord and I bought this car just 3 month before. Till yesterday it was good and running fine. Today when I was trying to start the car, it wouldn't start and I found, it's break system jam and break led is RED. When I am trying to start the car, all led in the panel start blinking and car wouldn't start. Please help me to understand the issue and what could be the reason foe the break jam ?
Thanks in advance to all
Old Oct 15, 2012 | 09:40 AM
I'm a bit confused. Jammed brakes shouldn't prevent the engine from starting. So you might have multiple problems...
The handbrake can jam from corrosion in the cables, or something like that. If you are only going by the handbrake warning lamp, you should also check whether the brakes are actually jammed. Low brake fluid can also set off that warning lamp.
hondaisreal
Oct 28, 2012 09:01 PM
mikem13
Oct 9, 2012 04:02 PM
datamonkee
Oct 22, 2008 08:15 AM
JasonV
Sep 29, 2006 12:53 AM
flomasta
Feb 3, 2006 03:01 PM
