Honda Accord 2013, 2.0 D headlight
Old Jul 20, 2023 | 01:52 AM
Terje1981's Avatar
Default Honda Accord 2013, 2.0 D headlight
Hi, I am looking for some advice regarding my headlight on my Honda Accord. I notice the right headlight low beam and high beam did not work sufficiently. Once I start car, there is low light in the beginning before it becomes all dark. The right side low head and high is not working at all after some minutes.
I tried to locate the bulb for replacing, but can not find it. Does that mean this is led type. I find all the other bulbs but not the one for the headlight.
I did check the fuses, but they all seem ok. Could it be a relay that is causing this or is it the led light itself.
Anyone have any recommendations for me I would appreciate it very much.
It says also in the manual that if the low headlight are LED type, one should have a authorized Honda dealer to inspect and replace the light bulbs. Would that be neccessary, or is it something normal people can do?
Thanks in advance for any help.
Old Jul 20, 2023 | 05:29 PM
I remember reading the LED headlights on your accord has a 10 year warranty, so the dealership may be able to replace them. It is worth a call.
Old Jul 21, 2023 | 01:46 AM
Terje1981's Avatar
Hi, will try that. Thanks for the tip!
But if not, any idea where to get new and ho to replace?
Old Jul 22, 2023 | 11:28 AM
I think the LED is part of the headlight assembly, so I don't think you can easily replace the bulb. There may be a writeup or youtube video on how to separate the lens cover, then replace the LED strip for your accord.
Raleighwood007
Oct 2, 2015 12:06 AM
o CRA5H o
Apr 24, 2011 08:23 AM
status
Aug 15, 2008 08:03 PM
gripper
Mar 30, 2008 05:33 PM
howie
Feb 18, 2008 03:05 AM
